robert.higginson
Is it possible to operate the "t4 PICAXE Trainer" - part number AXE055 - using a 3xAA battery pack - similar to the other kits?
Until Technical gives a definitive reply,Could this then be powered by a 9v battery?
Could I connect it to the power test points (in/grd/out) just below the power socket?
The reasons behind the question is that I am about to get students to create programs for the picaxe range and will be teaching them in a normal classroom and so there will be no access to a mains socket to operate the power supply.
Its on the Rev Ed website. Just no obvious linkWelcome to the Forum.
Unfortunately, I can't find the datasheet. :-(
e
and considerSome of the outputs (LED, 7 segment display, piezo, servo) can be disabled via use of the 4 pin DIL switch
anything connected to that terminal in the lower right corner?Output 0 is also connected (without buffering) to a terminal block at the lower right hand corner. This is for
connection of digital output devices e.g. the AXE033 Serial LCD module or USB030 MP3 module.
