I'm looking at ways to store and recall strings of ASCII text on a Picaxe 18M2
I know I can store a string in EEPROM with a start address, e.g.
EEPROM 10,("Voltage VC1=6.23")
I am also assuming that this will require 1 byte for every character (including spaces) 16 bytes for above example.
Is there any way to store the string like
"Hello World" other than in EEPROM?
b0 - b127 on M2 parts only store 1 byte and w0 - w13 store 2bytes each, if I have understood Pixaxe Manual 2 correctly,
so a string like "Hello" could not be stored in the above location as it is 5 bytes long.
Ultimately I am trying to display lines of text on a 1602F LCD display, working in 4 bit mode.
It will be much easier for me to use the AXE033 module and send strings serially, but just thought I'd ask
if there are alternative ways of storing and recalling ascii strings.
Thanks in advance.
Thanks in advance.
