Stop Program After X Seconds
On the PICAXE M2 chips you can use the 'time' variable which increments about once every second, so can take action when 'time >= 120'.
And after the 2 minutes / 120 seconds, use the
STOP command
Which will stop all action until the power is cycled.
PhilHornby
M2 Series multi-tasking....
I need to stop my program after 2 Minutes, is there any way to do it, like an internal timer or multi threading?
Something like this? :-
[COLOR=blue]Start0:
            [/COLOR][COLOR=green];
            ; This is the main program...
            ; ...running at 16MHz
            [/COLOR][COLOR=blue]Sertxd (cr[/COLOR][COLOR=black],[/COLOR][COLOR=blue]lf[/COLOR][COLOR=black],[/COLOR][COLOR=red]"Main program here"[/COLOR][COLOR=blue])
Start1:
      Pause [/COLOR][COLOR=navy]60000       [/COLOR][COLOR=green];wait one minute
      [/COLOR][COLOR=blue]Pause [/COLOR][COLOR=navy]60000       [/COLOR][COLOR=green];wait another minute
      ; we could just stop both tasks...
      [/COLOR][COLOR=blue]end   [/COLOR][COLOR=green];(stop could be used - which doesn't power everything down)
      ; ...or just the main one...
      [/COLOR][COLOR=blue]suspend [/COLOR][COLOR=navy]0
      ; ...in which case, we can carry on and do other things here
      [/COLOR][COLOR=blue]sertxd(cr[/COLOR][COLOR=black],[/COLOR][COLOR=blue]lf[/COLOR][COLOR=black],[/COLOR][COLOR=red]"Task 1 still alive"[/COLOR][COLOR=blue])
      [/COLOR][COLOR=blue]end [/COLOR][COLOR=green];?[/COLOR]
Tiago Severino
Hi Welcome
Doe's it need to restart after another time period
john
I just need to shutdown after 2 minutes
I know but time doesn't increment when in pause command, and I'm using some functions with pause command
STOP command
Yes, but I need to know when it passed 2 minutes since program elapsed
[COLOR=blue]Start0:
Start1:
Will Start0 and Start1 run in parallel? Gonna try it
I just need to shutdown after 2 minutes . . . I know but time doesn't increment when in pause command, and I'm using some functions with pause command
time certainly does increment during pauses.
#picaxe 08M2
pause 5000
sertxd(#time)
This prints "5".
If some of your pauses might carry you over the 120 second mark, break up the pauses into smaller pieces and check time in between pauses.
Tiago Severino
#picaxe 08M2
pause 5000
sertxd(#time)
This prints "5".
Oh my bad, it just don't increment with sleep command, thank you!
