Steve2381
Hi all
I had a thread a short while back regarding my circuit that was suffering from the HC-06 bluetooth module messing up the I2c comms to a 14m2. I temp fixed it by using multiple 7805's.
I designed a proper PCB and put plenty of smoothing caps across basically everything.
Also, a 10R resistor in line with each IC on the board and the HC-06.
The whole unit runs off a 230v to 5v - 1A PSU.
It doesn't work.. the 08m2 takes the information from the HC-06 and transfers it to a 14m2. If I remove the HC-06 from the circuit and run it on its own 5v supply, it works again.
How can I get over this? Something in that HC-06 module is messing up my circuit.
I have no way of adding another 5v supply anywhere, as the whole module has to run off the 230v - 5v PSU.
Any other ideas what might be causing the power supply issues and any remedies?
Someone did suggest a choke. Never used one. What does it achieve and what one to use?
Any help would be great.
