I have a 1.2v output from a separate timer which I want to connect to leg 4 of a picaxe 08 chip. I need at least 2v to get a logical 1.
I can use an op amp to step up the voltage but it means an extra chip and two extra resistors.
I also have a 3v supply in the circuit which would be ideal if i could connect it to leg 4 using a transistor or a mosfet using the 1.2v output of the timer to the base of the transistor. The problem is leg 4 doesn't seem to draw any current so this won't work.
Any ideas or is the op amp the best solution?
Thanks
Dermot
Thanks
Dermot
