Stack error - more nested gosubs than the stack allows
Not sure how to correct this error in the following code (stack error more nested gosubs than stack allows)......any suggestions
main: Symbol cycle = b50
       Symbol rsteps = b49
       Symbol lsteps = b48
       Symbol pin1 = 1
       Symbol pin2 = 2
      if pinc.1 = 1 then 'move stepper left
        pause 2000
       gosub moveleft
    if pinc.2 = 1 then 'move stepper right
      pause 2000
       gosub moveright
    if pinc.3 = 1 then 'teach mode left
      b0=0
       gosub teachleft
      if pinc.4 = 1 then 'teach mode right
      b0=0
       gosub teachright
moveleft:
       b1 = b1 + 1 & %00000011
       let b0 = b0 + 1
    if b0 < 5 then moveleft 'step multiplier for gear ratio
       b0=0
moveright:
      b1 = b1 - 1 & %00000011
      let b0 = b0 + 1
    if b0 < 5 then moveright 'step multiplier for gear ratio
      b0=0
teachleft:
       IF  pinc.1 = 1  THEN
          let b0 = b0 + 1
        if b0<5  then teachleft 'step multiplier for gear ratio
          lsteps=lsteps+1
       ELSEIF pinc.5 = 1  THEN
           gosub writeleft
       ELSE
            pinc.1 = 0
       ENDIF
teachright:
       IF  pinc.2 = 1  THEN
          let b0 = b0 + 1
        if b0<5  then teachright 'step multiplier for gear ratio
          rsteps=rsteps+1
           gosub writeright
       ELSE
            pinc.2 = 0
       ENDIF
writeleft:rsteps=2
      write cycle,pin1,lsteps,rsteps
      cycle= cycle+1
      gosub main
writeright:lsteps=0
      cycle= cycle+1
      gosub main
 cyclestart:'code to be added
tiscando
Hi triton,
In the code, I can see that there is no return command on the subs 'teachleft' and 'teachright'.
Also, you have some 'gosub's which should be 'goto's. Do not confuse 'gosub' with 'goto'.
hi
using a input pinc.5 for the return to main.....was looping until the the stepper reaches disired postion then pinc.5 = 1 will write the steps and direction....well in theroy anyways
MartinM57
Yes, but your code is fatally flawed :(
moveleft: and moveright: are subroutines (you gosub to them) and they end with a return.
teachleft: and teachright: are subroutines (you gosub to them), but don't have any returns at the end
writeleft: and writeright: are subroutines (you gosub to them), but don't have any returns at the end - you have "gosub main" though - which is no good at all.
Just step through the code manually (i.e print it out and follow it with your finger) and you'll soon see how the compiler/PICAXE get confused....
lbenson
As an example, here is your "teachright" realigned to make the structure more clear.
teachright:
         IF  pinc.2 = 1  THEN
           let b0 = b0 + 1
           rsteps=rsteps+1
           gosub writeright
         ELSE
           pinc.2 = 0
         ENDIF
There are several problems here. The first, as pointed out above, is that this subroutine has no return. Another is "if b0<5...". This make a "goto" jump out of the loop to the beginning of the subroutine. This is not necessarily wrong, but it might be more clear if the test were reversed as follows, which has the same effect (starting the loop over when b0 < 5.
teachright:
         IF  pinc.2 = 1  THEN
           b0 = b0 + 1
           IF b0 > 4 then  'step multiplier for gear ratio
             rsteps=rsteps+1
           ENDIF
           gosub writeright
         ELSE
           pinc.2 = 0
         ENDIF
But the big problem is, how do you get out of this loop.
Try your whole program in the simulator to see where it goes when the different inputs are on or off.
