I pulled the following from a 2004 thread:
"The method you are after is the same as that used by robots for obstacle avoidance. It is called "vector forces". Draw your robot's outline on a peice of paper and consider the forces that your motor/wheels apply individually. Draw these as vectors. Then do the same for your controller.
It now becomes a case of trigonometry. (it's that funny stuff that didn't make sense at school involving triangles and degrees). You will then end up with a set of equations that involve trig functions and numbers between 0 & 1.
The poor old PICAXE can't do any of that, so back to the drawing board.
Start building up a set of values in a grid as you have already suggested.
You only actually need 3 or 4 steps for good control.
Break each stick position into areas that contribute an amount of demand for each motor. For example, pushing the stick 1/4 to the right (no forward or back component) needs to add 1/4 drive to the left motor and subtract 1/4 drive from the right. Robot turns right on the spot at 1/4 speed. Then move the stick half way forward as well as the 1/4 right. Forward/backward movements adds equal amounts to each motor so now add half demand to each motor. This results in the left motor having +1/4 from the left right stick plus +1/2 from the forward/back stick = +3/4. The right motor has -1/4 from the left/right stick plus +1/2 from the forward/back stick = +1/4. Net result is move forward whilst turning to the right.
Now you know what to do with respect to motor speed demand for each stick position it is a question of converting to PICAXE code.
Be aware that positions such as FULL forward and FULL left can result in more than 100% demand. You need to put limits on the calculations.
The method I have used is to have a seperate PICAXE for each drive. Both channels receive the radio signal and present the resultant demand as a pulsout to a regular RC speed controller. This allows me to include sensor inputs as well so that I can switch between RC and fully automomous or even combinations."
I made a spreadsheet of the upper right quadrant of the stick movement and got the values below. My interpretation of the above indicates a problem with my spreadsheet values. Can someone clarify my understanding please
L=left mtr R=right mtr
F/W STICK POSITION
1.00 | L+1.25 R+.75 | L+1.5 R+.5 | L+1.75 R+.25 | L+2 R0
0.75 | L+1 R+.5 | L+1.25 R+.25 | L+1.5 R0 | L+1.75 R-.25
0.50 | L+.75 R+.25 | L+1 R0 | L+1.25 R-.25 | L+1.5 R-.5
0.25 | L+.5 R0 | L+.75 R-.25 | L+1 R-.5 | L+1.25 R-.75
0.00 0.25 | 0.5 | 0.75 | 1.00 L/R STICK POSITION
| L+.25 R-.25 | L+.5 R-.5 | L+.75 R-.75 | L+1 R-1 TURNS IN PLACE RIGHT
Sorry about the primitive text usage, I don't really know what would have been more appropriate here and probably don't know how to "create" that
F/W STICK POSITION
