It doesn't look like many people have interfaced this display with PICAXE before. All I found was
this where a similar Sparkfun display was used in serial mode.
The i2c address to use with PICAXE is $E2.
Have you read the
Basic Usage guide? Basically wherever it uses the Serial.write() command, you need to use
hi2cout.
For example, this example:
Serial.write(0x01); // Hex value for 1, will display '1'
Serial.write('2'); // ASCII value for '2', will display '2'
Serial.write(0x0A); // Hex value for 10, will display 'A'
Serial.write('B'); // ASCII value for 'B', will display 'b'
becomes this on PICAXE:
hi2cout (0x01) ;Hex value for 1, will display '1'
hi2cout ("2") ;ASCII value for '2', will display '2'
hi2cout (0x0A) ;Hex value for 10, will display 'A'
hi2cout ("B") ;ASCII value for 'B', will display 'b'
The commands above are on individual lines to make it clearer. They can be combined onto a single line like this: hi2cout ($01,"2",$0A,"B")
Both $ and 0x mean hexadecimal.
At the beginning of your code, you need to use the
hi2csetup command. Use hi2csetup i2cmaster,$E2,i2cslow,i2cbyte
