One of for collective...
I have a batch (>1000 ) of white LEDs from a reputable manufacturer and reputable supplier.
Each LED in isolation is qualitatively "white" but with say 20 all powered up and compared to each other they are a different white - some are warmer (yellower - lower degrees K) some are cooler (bluer - higher degrees K). But I don't know the range - maybe 7000K to 1000K?
I need to sort them into batches that visually look the same - I assume this is batches with a small range of colour temperature e.g 7001-7500, 7501-8000, 8001-8500 etc
What (cheap) colour sensor can I plug into a PICAXE to point each LED at, one at a time, to measure the colour temperature to that sort of accuracy will allow me to allocate them into batches that visually look the same "whiteness"
..or am I on a hiding to nothing?
For those wanting more detail, the LEDs' data sheet is at
http://docs-europe.electrocomponents.com/webdocs/12d3/0900766b812d38bc.pdf
and the part number is C503D-WAN-CCbDb232 which equates to LEDs in colour bins W2 and W3 on page 5 of the data sheet which look to be from about 7000K to 10000K, hence the numbers above
