1968neil
Has anybody any experience of the SOMO 14D from 4D systems ?
I have had a play with the module using the recommended switches etc and it appears to be VERY GOOD !
I need to address it with a PICAXE : ie press switch and it will play the sound stored etc.
It appears to use an SPI bus and i have little or no experience here. RS232 im ok with.
Could anyone give me an example code just to get it to play ?
also it runs from a 2.7 to 3.6 v supply thats not a problem, however do i need to protect the inputs from the picaxe ? It says you need 470R series resistors ? no pull ups or downs is this normal ?
this module could be ideal for speech applications using high quality audio rather than the old allophone methods ! Goodnight speekjet ?
prefered Axe = 08M
Thanks for any help. (keeping it simple !)
Glad this forum is here id be lost !
Regards
Neil
prefered Axe = 08M
Regards
Neil
