Hi guys,
I am totally new to this and have taken on a water drop controller and helped by bfgstew. Thanks m8.
I think I've done his head in enough now with little questions and ideas I had so have to ask here as this is my final step to having my controller working perfectly.
I'm out of memory on my 18M2 and need to cut the code down.
Now, I know nothing of starting and writing code, but have totally managed to fumble my way through the basic code Stewart sent me and added a lot of extras into that. It may, to you guys who know code, seem like a long winded burble, but it works so that will do for me.
What I am looking to do is add fine tune options into my code.
At the moment, what I have is a separate adjustment menu for each drop and interval, so 4 menus there, and one for each of camera delay and flash lag, 6 in total. If I go to adjust a value, I can then go to a menu to adjust that value, BUT, due to me having to have all these sub menus, and the lack of room thereof, I can't adjust them in both normal and bulb modes. Only one. Shame that.
I need a menu that will allow me to adjust whichever value i want changed, then go back to either the bulb or norm modes, where I sent the command from.
So, I am shooting in bulb mode, needing to adjust flashdelay (w7) I press my key to adjust this value, send it to the menu then it goes back to bulb mode and runs the program again with my adjusted value.
I want this option in normal mode too but I can only add another menu for that option with a goto runnorm after it. Can this be done in one menu?
I will post the code I have put together and hope there is a way to put them all together into a single menu.
Does anyone know how I can sort this as I have nearly gone bald trying to work it out.
Cheers.
Steve
Cheers.
Steve
