Hey all,
I have built a circuit to fire a solenoid when an infrared beam is broken, but I need to reprogram my Picaxe 08m2 to make the delay that the solenoid stays engaged for. I can program a brand new 08m2, but when I try to reprogram the chip it says Hardware Not Found. I can reprogram the transmitter circuit fine, but my receiver Picaxe won't reprogram. The receiver works fine, even after I attempt to reprogram it, I just can't adjust the solenoid delay.
Other details:
I am using output c.4 to drive both a red led (with resistor) and the base of an N-channel mosfet transistor, which drives the solenoid.
I am using a diode on the solenoid to protect my mosfet.
I am powering the mosfet and solenoid with a 24v power supply.
I am powering the Picaxe with 3 AA batteries.
The 0v connection from the batteries is connected to the 0v connection for the power supply.
I am reprogramming the chip on a separate breadboard powered by a computer ATX power supply.
Chips that have not been in my solenoid circuit reprogram fine.
What could be going on in my solenoid circuit that is causing my Picaxe chips to become non-reprogrammable.
Thanks for any thoughts,
Brian Z
Other details:
Brian Z
