After a lot of breadboard projects..I want to start making more permanent circuits. I need to decide on a soldering iron.
I'm confused by the fact that I know too much heat can damage the picaxe..and other ICs and components. But other things I have read say if the iron is too underpowered it won't be hot enough to work well and quickly. I have an 18W Antex at the moment, with slot on tiips, but the tip seems to oxidise immediately you heat it up..tinning is almost impossible after a few uses.
What sort of wattage should I be looking for to solder picaxe chips and other delicate objects? Is there one iron which would do everything? Is 40W ok...or would it burn out my chips? What about 80W?
I have seen a few which might fit the bill...
http://www.axminster.co.uk/weller-weller-2012-fine-soldering-iron-prod23610/
http://uk.rs-online.com/web/p/soldering-irons/7683615/
http://uk.rs-online.com/web/p/soldering-irons/7683567/
My budget is around the 20-25 quid range..what would you guys recommend>
