flyingnunrt
Although not having tried this approach myself you could try this.
While you're at DSE, buy the cheapest NON alkaline dry cell battery that you can find.
Carefully cut it open and the paste stuff that you find inside the cell is mostly Ammonium Chloride AKA Sal Ammoniac, you can water it down a little to make a liqiud and this can then be used to clean the tip by plunging the tip in the liquid when the iron is good and hot.
If the tip is nice and hot the sound made by the action of the quench is somtimes quite shrill as opposed to quenching sound with say straight water.
The tip should come out clean as a whistle ready for tinning, which should be done without delay.
It won't wreck the iron/nickle plating like sandpaper.
Avoid breathing in the vapours wear protective glasses etc etc.
