For my school project next year (the teacher has advised us to think about our designs and such now), I want to build a weather station type thing. One requirement is that our projects must be powered by renewable energy. I thought it would be easiest to use a solar panel.
So, I decided that I would use a solar panel and a pair of Ni-MH batteries. I would need some type of sensor to detect when the solar panel wasn't providing enough current to run the circuit (ie it's too dark) and switch over to the Ni-MH batteries. I would use some form of voltage step-up to increase the batteries from 2.4 V up to 5 volts. I would also want the batteries to be charged whenever the circuit was currently being powered by solar.
So, my question is, how would I go about detecting the current? Also, I understand that I need a solar regulator for the solar panel. Could I just use a 9 volt panel and a 7805 + caps?
EDIT: For the solar charging, would either of these be appropriate?
http://www.futurlec.com/Maxim/MAX713.shtml
http://www.futurlec.com/Maxim/MAX712.shtml
