Snap Switch
motherhugger
is this connection right?
if the switch is pressed it is high right?
i cant understand the manual...
im using picaxe 28x1 starter pack...
thank you in advance
motherhugger
so the connection is correct? no need for resistor? in all 3-pin snap switch..the right most is the +V and the middle is GND?
so this code:
if pin 2 = 1 then light
light:
high 0
if the switch is pressed LED on out 0 lights up....
hope im correct coz im gonna test it later... im just afraid i would fry the thing...
thank you for your help...
