Overview...
Ok. The proof of concept bit is finished, it works, but it is still being enhanced and its performance is being explored and it is not in a box yet.
I could not find anything quite like this in the projects, so I thought it was worth posting.
The concept...
To make a simple accurate calibrated reproducible radiation detector primarily aimed at measuring low levels of nuclear background radiation with a digital output reading.
To compensate for the lack of sensitivity and low count rates by using a microprocessor to patiently work as a rate meter.
To use a solid state low voltage radiation detector coupled with a Picaxe.
I am not saying you need one of these, unless you have an enquiring mind and a hobby interest and curiosity in measuring something we have no senses for i.e. Nuclear radioactive decay. We live in a world where quantum effects are not perceivable, not until you get one of these that is. Nuclear radioactivity has been around since the beginning of the universe so we have a long relationship with it.
I'm afraid the cost of the bits it likely to be a bit over £100 so stop here if that puts you off. I am writing it up with results, but I thought I would just see if these is any interest out there.
It is sensitive enough to react to a tub of 'LoSalt' because of the Potassium Chloride it contains.
HertzHog.
The concept...
HertzHog.
