Dont think so, I would have suggested it otherwise ...........Is there anyway that I can create a single command for the whole data input that will slow it down instead?
Not a proper command. You can use a lookup table with serout command in a for:next loop which will be handy if you want to send a long string. The for:next loop on its own might be enough to eliminate the need for the pause command.Is there anyway that I can create a single command for the whole data input that will slow it down instead?
