Installing LinAXEpad from a Command Shell
Login as a root user then open a Command Shell; under Gnome that will be Terminal, under KDE that will be Konsole. Create a LinAXEpad directory under the Home Directory and move into that directory. For example -
user@linux:~$ mkdir ~/LinAXEpad user@linux:~$ cd ~/LinAXEpad user@linux:~/LinAXEpad$
Locate the downloaded LinAXEpad.tar.gz file then use the tar command to extract the contents into the LinAXEpad directory. The path will be the directory where the LinAXEpad.tar.gz file was downloaded to -
user@linux:~/LinAXEpad$ tar -xvzf path/LinAXEpad.tar.gz
Use the chmod command to ensure the LinAXEpad application is executable -
user@linux:~/LinAXEpad$ chmod 755 LinAXEpad Launch the LinAXEpad Application using -
user@linux:~/LinAXEpad$ LinAXEpad
I'll try the Windows app w/WineIndeed page 8 of the relevant instructions.
I would except for the activation hassle. I don't have internet on the pc in my lab and seemI would just stick with plain Windows if you don't have any Linux experience.
If you want to eliminate the need for reactivation when you want to reinstall, do the reinstallation and activation once, install all the updates, then create an Automated System Recovery backup. When you next want to 'reinstall', run Automated System Recovery.I would except for the activation hassle. I don't have internet on the pc in my lab and seem
to need to reinstall every so often. Thanks for the advice .....
Has Rev-Ed made an *.deb file of linAXEpad? The apt-get -install command applies to already made packages.Thanks All !
I installed Zorin (supposedly Ubuntu based) on HD.
(second PC (no internet))
(on first PC (XP)
Downloaded LinAXEpad.
Unzipped two times and copied to USB stick
When I put stick in second PC and from terminal:
sudo apt-get install LinAXEpad
I get "cannot find LinAXEpad"
Seems I'm on the verge, but not
using proper name or address or ?????
Would you please post the commands you use to do the above ?I'm running Kubuntu 12.04. This is how I'm doing it:
The linAXEpad is downloaded and unzipped. I start a terminal, then manouver to the dir linAXEpad is and write sudo ./LinAXEpad - voila. There it is, running with root prevs and full access to the serial programmingport.
- nerdegutta
