robert.higginson
I am attempting to link a CHI030 (old style) board with a 18M2 picaxe to several very simple input and output devices and it may just be getting late but I cannot seem to be able to make it work.
I have connected simple push to make switches to input marked 0-1-2-6-7, I believe that the RESET switch is really input 5 when using a 18M2, and LEDs to output marked 7-6-5-4.
If I use Logicator and use the ICE facility the LEDs can be turned on/off but only input 6 & 7 seem to work. I have tested the connected and switches and these seem to be fine. I have tried the Picaxe editor and that also fails to see the inputs on 0-1-2.
When I 'calibrate' the adc inputs the values change to 255 when I press the switch - I have no intention of using the ADC facility - just simple digital on/off inputs.
Can any see the wood for the trees - I'm sure that I am not seeing the obvious!
Thanks
Thanks
