' AXE106 Simon Says Game
' *** Define the variables used ***
' Push switches on inputs C.0,C.1,C.6,C.7
' Preset (speed) on input C.2
' LEDs on outputs B.0-3
' Piezo on output B.7
symbol randword = w0 ' random number store for loading memory
symbol randbyte = b0 ' random number store for loading memory
symbol value = b2 ' switch value 0-1-2-3
symbol playerstep= b3 ' position of player in game
symbol freq = b4 ' sound variable
symbol topstep = b5 ' number of steps in sequence
symbol counter = b6 ' general purpose counter
symbol speed = b7 ' speed of playback
' *** Section 1 **********************
' *** This section waits for start ***
' wait for any switch to be pushed
' with all four LEDs lit
' preload rand with any number by repeatedly
' using the random command in the loop
init:
let dirsB = %11111111
let pinsB = %00001111
random randword
if pinC.0 = 1 then preload
if pinC.1 = 1 then preload
if pinC.6 = 1 then preload
if pinC.7 = 1 then preload
goto init
' *** Section 2 ****************************
' *** This section loads memory for game ***
' load EEPROM data memory with 30 numbers
' first get the random number (0 to 255)
' and then change to either 1,2,3 or 4
' and then save into data memory
preload:
let pinsB = %00000000 ' all LEDs off
for counter = 0 to 30 ' for..next loop
let value = 0
random randword ' get random number 0-255
if randbyte > 180 then set0
if randbyte > 120 then set1
if randbyte > 60 then set2
set3: let value = value + 1 '1+1+1 = 3
set2: let value = value + 1 '1+1 = 2
set1: let value = value + 1 '1
set0: '0
write counter,value ' save in data memory
next counter ' next loop
' *** Section 3 ****************************
' *** This section plays back a sequence ***
' switch off the LEDs and then start
' a game with the end counter as 1
let pinsB = %00000000 ' LEDs off
let topstep = 1 ' reset step number to 1
' playback the game sequence
playback:
' first read the playback speed
readadc C.2,speed
' now do a playback
for counter = 1 to topstep ' for...next loop
read counter,value ' get value
gosub beep ' make the noise
pause 300 ' short delay
next counter ' loop
' *** Section 4 *****************************************
' *** This section detects the players reply sequence ***
' now the user responds
' reset the players position to 1
playerstep = 1
gameloop:
' if playerstep is greater than topstep then all done
if playerstep > topstep then success
' get the correct key value is supposed to hit
' from the EEPROM memory
read playerstep,value
' now wait for switch to be pressed
sw_loop:
if pinC.7 = 1 then pushed0
if pinC.0 = 1 then pushed1
if pinC.1 = 1 then pushed2
if pinC.6 = 1 then pushed3
goto sw_loop
' switch pressed so check it is the correct one
' if it is make a beep sound and then continue
' else fail the game
pushed0:
if value <> 0 then fail
let playerstep = playerstep + 1
gosub beep
goto gameloop
pushed1:
if value <> 1 then fail
gosub beep
goto gameloop
pushed2:
if value <> 2 then fail
gosub beep
goto gameloop
pushed3:
if value <> 3 then fail
gosub beep
goto gameloop
' *** Failed so make noise and jump back to start ***
' failed so make failed noise, switch off all LEDs
' and go back to start
fail:
let pinsB = %0000000 ' all LEDs off
sound B.7,(80,100) ' make a noise
sound B.7,(50,100)
goto init ' back to start
' *** Succeeded so add another step to sequence and loop ***
' success so make a success sound
' and then increment topstep and do another sequence
success:
pause 100 ' short delay
let pinsB = %00001111 ' all LEDs on
sound B.7,(120,50) ' success beep
let topstep = topstep + 1 ' add another step
goto playback ' loop again
' *** Section 5 ****************
' *** sub light LED and beep ***
'sub-procedure to light correct LED
'and make a different beep sound for each LED
'value always contains number 0,1,2 or 3.
'add 1 and multiply by 20 to give larger difference
'in the sound noise
beep:
high value ' switch on LED
freq = value + 1 ' generate sound freq.
freq = freq * 25
sound B.7,(freq,speed) ' play sound
low value ' switch off LED
return ' return
