Hello ,
I've a problem with the command SHIFTIN ( SPIIN ) applied to 20X2 ...
I obtained a correct operation only if I defined C3 - C4 or C5 as pin "sdata" so that no such restriction is mentionned in the manual ...
More,modes 4 to 7 ( idle high ) does'nt work ( even at 8 Mhz ) while modes 0 to 3 ( idle low ) work seamlessly up to 64 Mhz !
( Note that replacing the 20X2 doen't modify the problem )
Is this normal ?
Thank you in advance for your reply .
Is this normal ?
