Quite true. Even with the same clock applied to 3 chips, each will start at slightly different times due to the internal oscilator being used for the startup..... they will initially start at slightly different times due to variances in the internal power on reset delay.
.... As ever some indication of the application would mean you get far better answers to the initial question.
The idea is to have 3 chips running from a single system clock so that they can be syncronised, so if they all run the same program they would all arrive at the end of the task together.
Phil.
Are you trying to make some sort of triply redundant system by any chance? I think each chip could set a pin high on reaching a certain stage, then read two input pins to see if its sisters have reached the same stage.what if the clock chip broadcasts an interrupt to each of the 3 chips, and each of the 3 chips begins it's program only when it receives that interrupt from the clock?
Indeed.Thanks for all the replies.
It just shows the the willingness of members to try to help out.
