Hello all, I have a new project I am working on and hit a snag. I am in the process of making an alarm clock out of an NES controller. I am using four seven segment displays (multiplexed) to show time obtained from DS1307 RTC. For now, I am just trying to display time on the seven segment display.
Now I did manage to obtain time data and convert it to display properly (bcd-->ascii-->decimal-->display mask). The problem is when time is displayed, it is out of order.
For example, say I am displaying the time 13:42. I would first display "1" then "3" then "4" then "2" which I call digit1, digit2, digit3, and digit4 respectively. However, when this is attempted, I get the display to show 34:21. It is rather odd, all of the time data is there but switched up in different places. To make sure it was not my code that converted time to display, I only turned on one digit at a time. So say I only chose to display the "3" in the same example, I would indeed get it to sit in the right spot, meaning x3:xx where x means the digit of the display is off (leds off). I also tried this with all places and they all sit in the right spot. However, say I now try to now turn on only two digits at a time, say, only the hour component, it would get switched up again and display 31:xx.
Code is below (sorry for the code size, most of it is just notes for myself) as well as a schematic. The schematic shows a display pre-wired to be multiplexed, my setup is equivalent but has separate seven segment displays, meaning, I wired it up to be multiplexed.
#rem
File........... NES_Controller_Alarm_Clock.bas
Purpose........ Alarm Clock Functionality
Author......... Joseph Corleto
E-mail......... jc269@njit.edu
Started........ 05/14/2012
Finished....... --/--/----
Updated........ --/--/----
Updates
#endrem
' EEPROM Data
' Constants
symbol bits = 8 ' number of bits
symbol MSBvalue = 128
' MSBvalue (=128 for 8 bits, 512 for 10 bits, 2048 for 12 bits)
symbol setsecond = $14 'set the current second here
symbol setminute = $45 'set the current minute here
symbol sethour = $20 'set the current hour here
symbol setday = $05 'set the current day here
symbol setdate = $01 'set the current data here
symbol setmonth = $03 'set the current month here
symbol setyear = $12 'set the current year here
symbol control = $10 'set the control here
' Variables
symbol second = b0 'holds what second it is
symbol minute = b1 'holds what minute it is
symbol hour = b2 'holds what hours it is
symbol day = b3 'holds what day it is
symbol date = b4 'holds what date it is
symbol month = b5 'holds what month it is
symbol year = b6 'holds what year it is
symbol counter = b7 'variable used during loop
symbol hourtens = b8 'holds tens place of the hour
symbol hourones = b9 'holds ones place of the hour
symbol minutetens = b10 'holds tens place of the minute
symbol minuteones = b11 'holds ones place of the minute
symbol var_out = w6 'data variable used during shiftout
symbol mask = w7 'bit masking variable
' Pin Declarations
'Inputs:
'Outputs:
symbol sdata = c.0 'serial data to feed into 74HC595(output pin for shiftout)
symbol latch = c.1 'latch pin for 74HC595
symbol sclk = c.2 'clock for 74HC595 (output pin)
symbol digit1 = b.0 'control pin for the hour's tens place
symbol digit2 = b.2 'control pin for the hour's ones place
symbol digit3 = b.3 'control pin for the minute's tens place
symbol digit4 = b.5 'control pin for the minute's ones place
' Initialization
#picaxe 18m2 'place directive here
setfreq m32 'run internal oscillator @ 32MHz
#rem
Note:This portion of the program is only needed to program the current time and
date. Uncomment this code for a fresh DS1307. If the DS1307 under test
already has current time preloaded, leave the bottom code commented.
#endrem
Set_Time:
'hi2csetup i2cmaster,%11010000,i2cslow,i2cbyte 'paramters set,18M2 is master
'hi2cout 0,(setsecond,setminute,sethour,setday,setdate,setmonth,setyear,control)
' Main
Read_Time:
hi2csetup i2cmaster,%11010000,i2cslow_32,i2cbyte 'paramters set,18M2 is master
hi2cin 1,(minute,hour) 'obtain minute and hour information from DS1307
Convert_Time:
bcdtoascii hour,hourtens,hourones 'convert hour data to ascii
let hourtens = hourtens - $30 'convert "hourtens" to decimal
'convert "hourtens" to be displayed on seven segment
lookup hourtens,(63,6,91,79,102,109,125,39,127,103),hourtens
let hourones = hourones - $30 'convert "hourones" to decimal
'convert "hourones" to be displayed on seven segment
lookup hourones ,(63,6,91,79,102,109,125,39,127,103),hourones
bcdtoascii minute,minutetens,minuteones 'convert minute data to ascii
let minutetens = minutetens - $30 'convert "minutetens" to decimal
'convert "minutetens" to be displayed on seven segment
lookup minutetens,(63,6,91,79,102,109,125,39,127,103),minutetens
let minuteones = minuteones - $30 'convert "minuteones" to decimal
'convert "minuteones" to be displayed on seven segment
lookup minuteones,(63,6,91,79,102,109,125,39,127,103),minuteones
Display_Time:
low digit1 'turn on tens place of the hour
let var_out = hourtens 'prep for shift out sub-routine
gosub shiftout_MSBFirst 'display tens place of the hour
input digit1 'turn off tens place of the hour
low digit2 'turn on ones place of the hour
let var_out = hourones 'prep for shift out sub-routine
gosub shiftout_MSBFirst 'display ones place of the hour
input digit2 'turn off ones place of the hour
low digit3 'turn on tens place of the minute
let var_out = minutetens 'prep for shift out sub-routine
gosub shiftout_MSBFirst 'display tens place of the minute
input digit3 'turn off tens place of the minute
low digit4 'turn on ones place of the minute
let var_out = minuteones 'prep for shift out sub-routine
gosub shiftout_MSBFirst 'display ones place of the minute
input digit4 'turn off ones place of the minute
' Sub-Routines
' ***** Shiftout MSB first *****
' Shift out the data MSB first from variable var_out
' Using clock output pin sclk
' Using data output pin sdata
' Note the number 128 (used twice) is the mask byte for MSB of 8 bits
' If using 10 bits use 512, 12 bits use 2048 etc
shiftout_MSBFirst:
for counter = 1 to bits ' number of bits
mask = var_out & MSBValue ' mask MSB
high sdata ' data high
if mask = MSBValue then skipMSB
low sdata ' data low
skipMSB:
pulsout sclk,1 ' pulse clock for 10us
var_out = var_out * 2 ' shift variable left for MSB
next counter
pulsout latch,1
