Hi Guru's
Here I have a scenario in which I need to read specific BYTE's from an external LED&Keyscan matrix chip (Holtek - HT16K33), make alterations to individual BITS of the read BYTE and then write the BYTE back to the HT16K33. For understanding, there are parts of two different BYTES making up a row of 6 LED's.
The following CODE does work flawlessly, however each SETBIT line burns 3 BYTES of program space and CLEARBIT lines burn 7 BYTES. Is there a more program space efficient way I can do this?
It'd be nice if I could essentially say:
setbit Temp_Byte,{1st BIT},{2nd BIT},{3rd BIT},etc..
or better yet,
setbit Temp_Byte,(%10101010) in the hope of combining SETBIT and CLEARBIT in one command line, but obviously this does not work.
Any ideas spring to mind?
Thanks in advance.
Regards,
Mort.
or better yet,
HI2cSetup I2CMASTER, $E0, I2CFAST, I2CBYTE 'I2C Communication for HT16K33 - I2C Address $E0
'Initialize and setup HT16K33
hi2cout [$E0],($21) 'Turn on Oscillator
pause 2
hi2cout [$E0],($EF) 'Set LED's Brightness ($E0 = min), ($EF = max)
pause 2
hi2cout [$E0],($81) 'Turn on Display with no blinking
Symbol Temp_Byte = b0
Symbol ADC_Read = b1
Symbol ADC_In = C.2
readadc ADC_In, ADC_Read
if ADC_Read>=206 then
HI2CIN [$E0],$01,(Temp_Byte)
setbit Temp_Byte,6
setbit Temp_Byte,5
HI2COUT [$E0],$01,(Temp_Byte)
pause 2
HI2CIN [$E0],$08,(Temp_Byte)
setbit Temp_Byte,3
setbit Temp_Byte,2
setbit Temp_Byte,1
setbit Temp_Byte,0
HI2COUT [$E0],$08,(Temp_Byte)
elseif ADC_Read<206 and b9>=192 then
setbit Temp_Byte,6
setbit Temp_Byte,5
pause 2
clearbit Temp_Byte,3
setbit Temp_Byte,2
setbit Temp_Byte,1
setbit Temp_Byte,0
elseif ADC_Read<192 and b9>=177 then
setbit Temp_Byte,6
setbit Temp_Byte,5
pause 2
clearbit Temp_Byte,2
setbit Temp_Byte,1
setbit Temp_Byte,0
elseif ADC_Read<177 and b9>=163 then
setbit Temp_Byte,6
setbit Temp_Byte,5
pause 2
clearbit Temp_Byte,1
setbit Temp_Byte,0
elseif ADC_Read<163 and b9>=156 then
setbit Temp_Byte,6
setbit Temp_Byte,5
pause 2
clearbit Temp_Byte,0
elseif ADC_Read<156 then
clearbit Temp_Byte,6
setbit Temp_Byte,5
pause 2
Thanks in advance.
Regards,
Mort.
