From what I understand, reading through the manual, if I add a 16MHz resonator to a 28X2 it will automatically run at 64Mhz, there is no need to use the Setfreq command. Is this correct?
Suppose I have a circuit with the resonator connected can I override the 64MHZ with setfreq? I.e the picaxe normally runs at 64MHz but I want to slow it down in some instances with setfreq and then return to full 64MHz speed, presumably having to use setfreq again.
Cheers
Cheers
