R rmtucker Member Nov 18, 2012 #1 How do you set an input pin to high on startup in the simulator? ie The inputs are held high with pullups,How do you set this in the simulator?
N nick12ab Senior Member Nov 18, 2012 #2 Use a pause at the beginning of the program then set the pins high manually.
R rmtucker Member Nov 18, 2012 #3 Oh thats a pain!!! So i assume that the simulator does not take the pullup command into account either?
N nick12ab Senior Member Nov 18, 2012 #4 rmtucker said: Oh thats a pain!!! So i assume that the simulator does not take the pullup command into account either? Click to expand... I tried it and it didn't work.
