Let me first say that this is not my first project using servos. I'm using seperate power supplies and capacitors across the power pins of the picaxe. I know that those are common problems and I don't want anyone wasting there time by responding with those common responses.
I have a multiplexed output that is constantly being updated with a short loop routine. Once a minute I need to reposition one or possibly two servos.
As per the manual I'm using the servo command to initiate the servos and the servopos command to reposition them. However, the servos have a lot of jitter in them. I think that the jitter is because the picaxe is trying to output the timing for the servos while also looping through the program updateing the display - it's having a hard time doing both.
Here is my question. Is there a way to turn off the servo timing between uses - without the servo moving. I tried setting the output that the servos are on either high or low - which does turn the servo timing off - but the servos move.
I'm thinking about using the 2 outputs I'm using for the servos as inputs to a 08m which would then handle the servos.
