With the 08m2 can sertxd be used once a hsersetup command has been used?
What i want to do is receive serial data using Hserin, but as both pins of hserin and hserout are effected with the hsersetup command, and with the Hserout pin also the same pin used for serial out (C.0), can the sertxd command also be used when hsersetup is enabled.
I have not tried this, as still in the planing stage, but had a feeling there might have been an conflict issue.
