Serout / Serin help!?!
kredhead
I am making a personal safety bracelet and want it to be able to send out a signal via a radio transmitter when it is activated. I also want to set up the reciever module which will show that the signal has been sent and received.
I have been trying to use 2 x 08m chips to work this.
The code I have been using for the transmitter unit (transmitter chip) is -
if pin3=0 then alarm
if pin2=0 then batterylight
batterylight:
high 4
low 4
alarm:
let b2 = 22
let b3 = 36
let b4 = 48
serout,T2400, (b2)
serout,T2400, (b3)
serout,T2400, (b4)
The code I have been using for the receiver unit (receiver chip) is -
input 1
serin 1,T2400, b2
if b2<> 22 then goto main
serin 1,T2400, b3
if b3<> 22 then goto main
serin 1,T2400, b4
if b4<> 22 then goto main
high 2
pause 1500
low 2
But when I link them up on two experiment boards and try and get them to work together and communicate it doesn't work.
I was wondering if anyone would be able to help please as this is for my a level project?!?
eclectic
Welcome to the Forum.
First very quick response.
Please post your circuit(s) / schematics.
2nd. Have you tested the program in the Simulator?
(I have. And, err your first program won't work.)
3rd. Could you please describe what you want the
programs to do?
e
kredhead
For the transmitter programme when the switch connected to pin2 is pressed that an LED turns on (that bit works although I wrote pin2=0 instead of pin2=1 on my post!)
When pin3=0 I want to have a signal sent out of one of the pins which can then be picked up by the second picaxe chip. When the second chip receives a signal I want an LED to light up.
I think its the alarm section of this code which doesnt work and is where I need help!?
if pin2=1 then batterylight ' have corrected this bit
batterylight:
high 4
low 4
alarm:
let b2 = 22
let b3 = 36
let b4 = 48
serout,T2400, (b2)
serout,T2400, (b3)
serout,T2400, (b4)
I have attached my circuit diagram for the bracelet/transmitter code.
For the receiver I only need to set it up on the experiment board to show the signal is being sent.
eclectic
Just to be certain,
could you re-post the circuit diagram S
(Tx and Rx)
Larger
and clearer
and correct way up
please?
And Manual 2, page 158 for Serout syntax
e
kredhead
This is the transmitter circuit diagram, have tried to make it bigger
What is (Tx and Rx) - I'm new to this!
I did read pg 158 but got confused from it and ended up with the code which I put above.
I'm not being ditzy I just find programming a bit confusing but once I understand how to use the codes then I'm fine! Honest.
lbenson
Tx is transmit
Rx is receive
As e suggested, run your code in the simulator (download the Program Editor if necessary--it contains the simulator). That will tell you where the errors are which prevent the program from compiling, and will also enable you to step through the logic of your program to see how it will work in reality.
kredhead
Thanks!
Will try looking through this tomorrow at school and see if I can get it working and get my head around it.
kredhead
Oh quick question
Does it matter what numbers I put in the brackets and do I also need to put b1 into the brackets as well?
Welcome to the PICAXE forum.
1. Firstly, your SEROUT command needs to specify the pin number as well.
that is serout 0, T2400, (b2)
2. You may find it necessary to "pre condition" the radio transmitter with a series of 1's and 0's.
3. The receiver may not be fast enough to pick up the three separate data transmissions.
Instead of:
serout,T2400, (b2)
serout,T2400, (b3)
serout,T2400, (b4)
try
serout 0, T2400, (85, 85, 85, "ABC", b2, b3, b4)
maybe leave out the ABC part until you get something visible working.
then at the receiver
SERIN pin, T2400, ("ABC"), b2, b3, b4
followed by the IF...THEN tests.
and leave out the ABC part when not in the transmitter part.
kredhead
Ok I have tried doing the following codes
Transmitter
let b0=1
serout 0, T2400, (85,85,85,85,"ABC",b0)
pause 100
goto light
light:
high 2
low 2
receiver
serin 3,T2400,("ABC"),b0
if b0=1 then light
light: high 4
*pause 1000
*low 4
*pause 1000
*goto main
and it didnt work
I then tried to really simplify it and tried -
transmitter
let b0=1
serout 0,N2400,(b0)
receiver
serin 3,N2400, (b0)
if b0=1 then light
light: high 2
*pause 1000
*low 2
*pause 1000
*goto main
which didnt work either
Help!?!? Where am I going wrong?
Peter M
in post# 13 westy gives a pretty good clue!:eek:
have a good look at your circuit......... what pin is connected to data on the Tx ??????????
Good luck.:D
You could put an LED with a resistor accross your Transmitter input to see if anything is going into it too. Or even better a CRO, surely you have one of those at school?
oops, whats a 1 or 0 between forumites :rolleyes:
Really does come down to reading the manuals.
Heck, for all my experience I frequently refer to the manuals. (Ah Alheimerzer's I hear :D )
eclectic
@kredhead
I've built and tested two simple circuits
This works, as the receiver
;receiver
#picaxe 08M
serin 3,N2400,("ABC"),b0
if b0=1 then light
light: high 4
low 4
This works for the transmitter.
;Transmit
#picaxe 08M
let b0=1
serout 0, N2400, (85,85,85,85,"ABC",b0) ; ******
pause 100
goto light  ; **** not needed
light:
high 2
low 2
It also works with
 serout 1, N2400, (85,85,85,85,"ABC",b0)
I'll repeat the above hint.
Check the circuit in post #5.
e
Getting wireless comms working can be a pain. The best approach is to get a wired SEROUT to SERIN plus 0V-0V configuration working first -
' Transmitter
Do
SerOut ?,N2400,("UUUUUUUUUUUUUUUUUUUUUUUUUU")
Pause 20
SerOut ?,N2400,("OK")
High ?
Pause 500
Low ?
Pause 4500
Loop
' Receiver
Do
SerIn ?,N2400,("OK")
High ?
Pause 500
Low ?
Loop
Replace ? with appropriate pin numbers. If working, you should see the LED on transmiter and receiver flash once every 5 seconds or so. If it doesn't, check your wiring and pin numbers.
Once it works, connect SEROUT to the RF transmitter, RF receiver to SERIN. Everything should still work as before. Alter the N2400 to T2400 as necessary. If it doesn't work, it will require more investigation.
Once you have proven wireless works, then you can start adding more complicated things like responding to button pushes.
Also .. while you have to get the wireless working as described as the first step, consider how your application will actually work in the real world.
What you have is a 'cry for help' system. Not much good if the bad guys have you bound and gagged. What would be preferable is a system which requires you to confirm you are okay and not in danger, the absence of that setting off the alarm bells.
Consider what could go wrong with the proposed system ( battery dies, you cannot reach the alert button, you are too far from the receiver ) and then think about how it can still serve its purpose in those situations. It is probably better to have a false alarm than miss a real one.
Alarms
As hippy describes, a fail safe type arranagement is ultimately the way to go for the sort of reasons hippy explains.
Having a timer which is reset by an interrupt each time a valid radio transimssion is received is an option. Not specific to your project but here is some code I posted for a Bike Alarm thread the other day, which may serve as an example/starting point, once your radio link is working:
#PICAXE 08M
;***TRANSMIT***
;main:
;b0 = 1
;serout 0, n2400, (85, 85, 85, "safe", b0)
;pause 100
;goto main
; ***RECEIVE***
Init:
  ; first a 1 second LED pulse to show PICAXE is working
  HIGH 2
  PAUSE 1000
  LOW 2
  SETINT %00001000, %00001000 ; to interrupt when input 3 is high
Main:
  DO
; can do something else here if you want
  LOOP
Interrupt:
  SERIN 3, n2400, ("safe"), b1
  IF b1 = 1 THEN
    HIGH 2
    PAUSE 1000 ; turn LED on for 1 second
    LOW  2
  ENDIF
  PAUSE 1000   ; turn LED off for 1 second before repeating cycle
  DO
  LOOP UNTIL pin3 = 0 ; wait until pin 3 is low before returning to main do loop
  SETINT %00001000, %00001000 ; restablish the interrupt for next cycle.
  RETURN
Vroom
Its interesting what hear that wireless, simple put short command almost maximum security for serin and serout
example;
transmitter;
b1 = 19
serout 1,n300,("andy",b1)
receiver;
serin 1,n300,("andy"),b1 .
if b1 = 19 then
that all for simple.
Regards, Andy.
Vroom,
while what you propose will work and can be satisfactory for experiments and school projects etc, when it comes to alarms, security, emergencys, health and the like, it is far from failsafe as discussed in posts 18 and 19 for a project as proposed by kredhead.
