Serial to PICAXE via Download Cable
TX  to  PC  <-------------------------------| SO       |
                             ___            |          |
RX from PC  >----.------.---|___|---------->| Ix       |
                 |      |    ___            |          |
                .|,     `---|___|----.----->| SI       |
            22K | |        2 x 22K   |      `----------'
                |_|                  O         PICAXE
                 |                   O
                _|_ 0V              _|_ 0V
This is a simple trick to allow a PICAXE download cable to both program a PICAXE and for the PICAXE to use SERIN to receive from the PC and communicate back with SERTXD ( or SEROUT on 08/08M/14M ). All without unplugging the cable.
Remove link from SI to 0V to enable download.
Link SI to 0V to allow SERIN to function.
matt2466
                             ___            |          |
                 |      |    ___            |          |
                |_|                  O         PICAXE
                 |                   O
                _|_ 0V              _|_ 0V
Hi hippy may i know what "Ix" stands for? I'm guessing TX to PC would be pin2 and RX from PC would be pin3 on the DB9 connector?
And would it be possible to use anyother output pin besides pin0 to perform the serout command?
Any input pin, x being the pin number.
That's right, for a 9-way female socket.
Pin 0 ( SO on 08/08M ) is used because the cable is used for downloading and it needs to be Pin 0 for that. It is possible to use Pin 0 and any other Pin (Ox) but SO/Pin0 has to be part of the setup or downloading doesn't work. The other advantage of Pin 0 is that's what SERTXD uses so higher speed ( 4800/9600 baud ) transmissions can be used than with SEROUT.
TX  to  PC  <----.--------------------.----|<|----| Ox       |
                 |                    `----|<|----| SO       |
                 |                 ___            |          |
RX from PC  >----|-----.------.---|___|---------->| Ix       |
                 |     |      |    ___            |          |
                .|.   .|.     `---|___|----.----->| SI       |
            2 x | |   | |        2 x 22K   |      `----------'
            22K |_|   |_|                  O         PICAXE
                 |     |                   O
                _|_   _|_                 _|_ 0V
matt2466
                             ___            |          |
                 |      |    ___            |          |
                |_|                  O         PICAXE
                 |                   O
                _|_ 0V              _|_ 0V
Hey Hippy I have 2 qns. Why is there a need for an Ix pin for this connection? If my application is to just display temp readings on the PC can I use the serout 0 command?
None whatsoever. The circuit was for a "Serial to PICAXE via Download Cable", extended to allow both SERTXD and SEROUT back to the PC without having to swap cables after download or adding an additional serial to PC interface.
Yes. Just diode mix Output Pin 0 with Serial Out. If it's an 08/08M they are one and the same; simply connect Output Pin 0 / Serial Out to the PC.
tiscando
does the input pins have clamping diodes as well as the rx pin has. if not, then a zener diode between the in pin and the gnd (anode at gnd) is needed. i have looked at the bat85 schottky diode, but didn't look like the right specs.
Or add an external clamping diode between input pin and +V. As far as I'm aware that only applies to Input Pin 3 of the 08/08M.
matt2466
Hi Hippy
I do not need to make use of the serin command therefore I can ommit the Ix pin from the circuit right?
That's correct. It then becomes a standard download interface ( for the input part) so use the standard 10K/22K.
matt2466
Hi all
Suppose I have an 08M and and a bluetooth chip and both can be configured via the serial cable (TX & RX). Can anyone suggest a switching method where the TX and RX signals be toggled to either the 08M or the bluetooth chip?
Thanks in advance
Just use a DPDT ( double-pole, double-throw ) switch ...
                   O----------------< From XBee interface
TX to PC   <---O :     .-------.
                 : O---|---.   `----> To XBee interface
                 : O---'   `--------< From PICAXE Serial Out
RX from PC >---O             ___
                   O---.----|___|---> To PICAXE Serial In
                      |_|
                      _|_
