Hi All,
I had a bit of a breakthrough last night and I "THINK" I've worked out how to send the 20 bits of data to the HV5812 in 2 lots of 10 bits which is perfect for nixies and VFD tubes.
I'm interested in what others think of this code (glaring mistakes etc) and whether i could do it more efficiently.
Regards
Tony
Regards
Tony
symbol sclk = B.7 ; clock (output pin)
symbol sdata = B.5 ; data (output pin for shiftout)
symbol counter = b17 ; variable used during loop
symbol mask = w4 ; bit masking variable
symbol var_out2 = w5 ; data variable used durig shiftin
symbol var_out = w6 ; data variable used during shiftout
symbol bits = 10 ; number of bits
symbol MSBvalue = 512 ; MSBvalue ;(=128 for 8 bits, 512 for 10 bits, 2048 for 12 bits)
Main:
let var_out = 9
let var_out2= 10
let var_out2 = var_out2 + 1024
gosub shiftout_MSBFirst
pause 50
goto Main
shiftout_MSBFirst:
for counter = 1 to 10 ; number of bits
mask = var_out & 1 ; mask MSB
high sdata ; data high
if mask = 0 then skipMSB
low sdata ; data low
skipMSB:
pulsout sclk,1 ; pulse clock for 10us
var_out = var_out / 2 ; shift variable right for LSB
next counter
Vari2:
mask = var_out2 & 1 ; mask MSB
if mask = 0 then skipMSB2
skipMSB2:
var_out2 = var_out2 / 2 ; shift variable right for LSB
next counter
pulsout B.6,10
; I added this strobe output
