hi
just in the process of converting the sparkfun inventor's kit from arduino to picaxe. Which has been an interesting and enjoyable challenge but I must now return to an aspect that I cannot find a solution for, cascading LEDs from s.2 to s.9 and back again. The arduino uses an array to move from 2 to 3 etc. This would be easy if the shield outputs were all from the same port and in sequential order but they are not.
a simple shield base solution would be to:
A simple 28x2 solution would be to:
I want to do the second one of the shield base without complicating the wiring up (or changing it from the first example from above)
the next step would be to 'knight rider' it but don't want to individually code each LED.
Thought of a lookup table or using the scratch pad to store the binary sequence of the s.[pins] output but would need to change between the B and C ports.
the sequence would look like:
s.2 - pinsB = %00000100 or $04 or 4
s.3 - pinsB = %00000001 or $01 or 1
s.4 - pinsB = %00000010 or $02 or 2
s.5 - pinsB = %00100000 or $20 or 32
s.6 - pinsB = %01000000 or $40 or 64
s.7 - pinsB = %10000000 or $80 or 128
s.8 - pinsC = %00000001 or $01 or 1
s.9 - pinsC = %00000010 or $02 or 2
how do i change from pinsB to pinsC without making it too complecated - remeber this is activity 2 on an introductory set of activities. I don't mind introducing lookup tables or memory pointers as this is an extention activity but if i need to have too many complicated decision statements it will turn th euser off, especially when moving to the knight rider style of example.
Can anyone help?
thanks in advance - if there is no suitable solution I will leave it out - contemplated it already but thought I would give it to the great minds of the forum.
bye
tiny
'LEDs connected to s.2 to s.9 of the shield base
#sim axe401
#picaxe 28x2
#no_table
high s.2
pause 500
low s.2
high s.3
pause 500
low s.3
high s.4
pause 500
low s.4
high s.5
pause 500
low s.5
high s.6
pause 500
low s.6
high s.7
pause 500
low s.7
high s.8
pause 500
low s.8
high s.9
pause 500
low s.9
#sim none
#picaxe 28x2
#no-table
b0 = 1
dirsB = %11111111
pinsB = b0
if b0 = 128 then '%10000000 for binary or $80 for hex
b0 = 1 '%00000001 for binary or $01 for hex reset the led to the first one
b0 = b0 * 2 'set the next led on - see binary maths in the manual 1 for help
end if
pause 500
Can anyone help?
bye
tiny
