Hello Friends Picaxe, once but I need of their help in the forum, have I designed two modules with Picaxe 18X, and Soon with 28X or 40X, does the first one read a scale for the serial port, does read a ds1307, and a memory 24LC64, does each one of the heavy ones record, and this send them serial (does it date, hour, does weight, weigh -accumulated, weigh maximum, minimum), to other I do modulate with a screen LCD 16x2, with which I compare and do I verify and do I modify, and other things, until here all well, the detail is that in the company where I work it requires that certain fact is placed in the PC, for the port of the Keyboard, and read by a program (As a Gun of code of Bar), does the weight have to send it my card with Picaxe, please like I begin? I am not able to visualize the program neither the schematic design, here this them the code of the I modulate #2 of the screen LCD to see if they are located with me, I am from Venezuela, and theirs would thank them very much again for their valuable help, thank you.
The idea is that when a weight is received a serial plot it was sent by the keyboard where (as if one writes) a program will be waiting to capture this it is easy via serial for hyperterminal, but it is required that if I am in Excel or another program, for example where this the cursor is written the serial plot automatically. And here is where I not see the program or the design electronic. Thanks for your helps …. Signature Andersson
Â
Â
