Hi. Has anyone been successful in getting the Sphero SPRK+ to work with S2Bot and the BLED112 adapter?
On OSX 10.11 with the native S2Bot app, I see the BLED112 serial port listed correctly as /dev/tty.usbmodem1 and have selected it as the "BLED112 Serial Port." When I select "Sphero" in the "Target" drop down menu and click "Connect", S2Bot indicates the connection is successful. However, none of the tests work and no lights on the SPRK+ come on. When I load sphero_template.sb2 in Scratch 2 after S2Bot indicates a successful connection, the extension blocks appear, and the Sphero extension connection indicator is showing green in the Scratch 2 More Blocks panel. However, none of the extension blocks work.
I believe the SPRK+ is actually identical to the BB8 and Ollie in terms of the communications protocol. Not surprisingly, the SPRK+ is not detected when selecting either BB8 or Ollie from the target menu.
