My lovely brother gave me a URF/ERF pair for christmas. I love my brother
Questions
1: The datasheet says "The optimum chip antenna orientation is when laid flat, so best results are generally obtained
when the URF PCB is laid flat (parallel with the floor)."
Whilst I don't doubt RevEd's vast technical knowledge, I just can't get my head round this. In my mind (addled as it is) this would not give an omnidirectional radiation pattern but would, in fact, have two great null areas on the axis of the chip antenna. Surely to get an omni pattern the module should be mounted vertical ?
As I eventually intend to use these to control a robot, null areas are a no-no. Or am I barmy?????
2: The said robot will be used to wind up, impress, plague, etc my grandkids who range from 10 years old to 1 years old.
What sort of material could I use to protect the ERF module that is transparent to RF.
I had a quick google but got flumoxed quickly when they started talking about grp radomes being made with one layer of grp to match the frequency of the radio wave passing through it (narrow band) and then going on to mention multi-layer lay ups which may include a metal mesh layer (wide band).
Isn't there some common household object such as an aerosol cap for instance that could be pressed into service?
I'm asking here because I know there are several hams on this forum. I do intend to breadboard the ERF module and try a range test eventually.
Questions
