INIT:
counter = 0 'increases each PID period (1 second)
counter2 = 0 'counter for profile selection and setpoint updates
cracks = 0 'counter for 1st and 2nd cracks
roastlevel = 0 'adjustment for roast end temp
pwmout 3, 255, 1023 'set fan to full for a while to get going
pause 200 'pause to give fan time to start
do 'LOOP FOR PROFILE SELECTION
if input_button1 = 1 then 'Waits in this loop until button1 is pressed
loop while input_button1 = 1 'debounce
pause 200
exit
if input_button2 = 1 then 'increase counter2 if button2 is pressed
inc counter2
pause 200
if counter2 > 2 then 'reset counter2 if > 2
counter2 = 0
if counter2 = 0 then 'show which profile is selected
high manual_led
low ssr_led
elseif counter2 = 1 then
low manual_led
high ssr_led
high manual_led
high ssr_led
readadc10 manual_val, fanspeed 'read value for fan speed
if fanspeed < 350 then
fanspeed = 0
pwmout 3, 255, fanspeed 'set manual fan speed. Fan will go to auto when roasting starts
low manual_led
do 'LOOP FOR PROFILE CUTOFF TEMP ADJUSTMENT
if input_button1 = 1 then 'Waits in this loop until button1 is pressed. Then starts roast
pause 200
exit
loop while input_button2 = 1 'debounce
pause 200
inc roastlevel
if roastlevel > 5 then 'reset roastlevel if > 5 ie max 5 degrees adjustment
roastlevel = 0
if roastlevel <> 0 then
for z = 1 to roastlevel
pause 200
high manual_led
pause 200
low manual_led
next z
if counter2 = 0 then 'adjust cutoff temp
if manual_switch = 0 then 'having manual_switch down will give negative adjustment
roastlevel = profile1cutoff + roastlevel
roastlevel = profile1cutoff - roastlevel
roastlevel = profile2cutoff + roastlevel
roastlevel = profile2cutoff - roastlevel
elseif counter2 = 2 then
roastlevel = profile3cutoff + roastlevel
roastlevel = profile3cutoff - roastlevel
roastlevel = roastlevel + 1 'will cut off roast when setpoint reaches roast level + 1. ie. temp gets to previous setpoint
if manual_switch = 1 then 'manual_switch must be returned to off otherwise manual instead of PID
for z = 1 to 20 'gives warning if manual_switch is on. Time to switch it off if desired
high manual_led
pause 200
low manual_led
high ssr_led
pause 200
low ssr_led
next z
sertxd("Roast Temp Cutoff = ",#roastlevel)
'end
if counter2 = 0 then 'Send selected profile
sertxd ("Profile 1",13,10)
counter2 = 0 'set eeprom location for start of profile 1 storage
counter2 = 85 'set eeprom location for start of profile 2 storage
sertxd ("Profile 2",13,10)
counter2 = 170 'set eeprom location for start of profile 3 storage
sertxd ("Profile 3",13,10)
sertxd ("Time Setpoint Temp PID FanSpeed Cracks",13,10) 'Send column headings
poke INT_lsb, 0
poke INT_msb, 128 'set initial pid value to 32768. i.e. false zero
MAIN:
if manual_switch = 1 then 'Manual temp control
high manual_led
gosub GETMANUALVAL
gosub GETTEMP
gosub SETFANSPEEDHEATING
sertxd ("- - ",#t, " ", #PID, " ", #fanspeed, #13,10)
else 'Or PID Control
low manual_led
z = counter // 15
if z = 0 then 'Every 15 seconds update setpoint
read counter2, sp
inc counter2
if sp = 0 or sp = roastlevel then 'At end of profile send completed message
sertxd ("Roast Profile Completed",13,10)
gosub COOLBEANS
end 'END PROGRAM after cooling
if input_button2 = 1 then 'Send terminated message if button2 is pressed during roast
sertxd ("Roast Terminated",13,10)
gosub COOLBEANS
gosub DOPID 'RUN PID ROUTINE
gosub SETFANSPEEDHEATING 'changes fan speed based on current temp
sertxd (#counter," ",#sp," ",#t," ",#PID, " ", #fanspeed) 'Send serial data
if input_button1 = 1 then 'Add to serial data if button1 is pressed during roast
high manual_led
if cracks = 0 then
sertxd (" FirstCrack")
elseif cracks = 1 then
sertxd (" SecondCrack")
sertxd (" Crack")
inc cracks
sertxd (13,10) 'Add carriage return and line feed to serial data
inc counter 'Increase loop counter
for z = 1 to 100 'Manual PWM with 1 second period (adjust pause at end of main routine to get 1 sec period)
if z > PID then
low ssr
low ssr_led
high ssr
high ssr_led
pause 6
next z
high ssr 'Keep output high while doing PID calcs
high ssr_led
pause 45 'Adjust to get timing right on PID mode (1 sec PWM period)
DOPID: 'PID CALCULATIONS
gosub GETTEMP 'Get temp reading from thermocouple
peek INT_lsb, b4 'read old int value into PID w2 (PID)
peek INT_msb, b5
if PID > 49000 then
PID = 49000
PID = PID
if t <= sp then 'for negative errors
b0 = sp - t max 65 'error
w3 = Ki * b0 * dt max INT_MAX 'INTEGRAL..........................
PID = PID + w3 max PID_MAX 'Add new int value to previous int value
poke INT_lsb, b4 'store new int value w2
poke INT_msb, b5
w3 = Kp * b0 max PRO_MAX 'PROPORTIONAL......................
PID = PID + w3 max PID_MAX 'Int + Pro
else 'for positive errors
b0 = t - sp max 65 'error
PID = PID - w3 min PID_MIN 'subtract new int value to previous int value
poke INT_msb, b5
PID = PID - w3 min PID_MIN 'Int + Pro
poke PRO_lsb, b6 'store pro value w3
poke PRO_msb, b7
'goto SKIPDER
peek pt, b0
if t > b0 then 'temp increasing
w3 = t - b0
w3 = w3 * Kd max DER_MAX 'DERIVATIVE ......................
PID = PID - w3 min PID_MIN 'int + pro + der
elseif t < b0 then 'temp decreasing
w3 = b0 - t
PID = PID + w3 max PID_MAX 'int + pro + der
w3 = 0 'no derivative part
poke DER_lsb, b6 'store der value w3
poke DER_msb, b7
poke pt,t 'store current temp as previous temp
SKIPDER:
if PID <= 32678 then
PID = 0
PID = PID - 32678 'convert to range 1-20000
PID = PID / 200 'convert to range 1-100
'PID = 100
'peek INT_lsb, b6
'peek INT_msb, b7
'sertxd("INT: ",#w3,13,10)
'peek PRO_lsb, b6
'peek PRO_msb, b7
'sertxd("PRO: ",#w3,13,10)
'peek DER_lsb, b6
'peek DER_msb, b7
'sertxd("DER: ",#w3,13,10)
'sertxd("PID: ",#w2,13,10)
'pause 4000
GETTEMP: 'Manual SPI
high cs
low sck
low cs
w3 = 0
for z = 1 to 16
high sck
w3 = w3 * 2 + miso
low sck
next z
high cs
w3 = w3 / 8
t = w3 / 4
'sertxd (#w3, 13, 10)
GETMANUALVAL: 'Reads POT instead of thermocouple in manual mode
readadc10 manual_val, PID
'sertxd (#PID,13,10)
PID = PID + 1024
PID = PID / 20 'Convert adc value into the range approx 50 - 100
COOLBEANS:
low ssr 'Turn SSR off
low ssr_led
for counter2 = 1 to 240 'About 4 minutes cooling time
high manual_led
pause 250
low manual_led
pause 250
high manual_led
pause 250
low manual_led
pause 250
gosub GETTEMP
sertxd (#t, " ",#counter2 ,13,10)
if t < 40 and counter2 > 60 then 'end cooling if beans are < 40 deg. But minimum 1 min cooling
pwmout 3, 0, 0
low 3
exit
gosub SETFANSPEEDCOOLING
next counter2
if t < 50 then
pwmout 3, 0, 0
low 3
goto COOLBEANS
SETFANSPEEDHEATING:
fanspeed = sp * fanconstant2 / fanconstant3 'set fan speed based on current setpoint
fanspeed = fanconstant1 - fanspeed * 4 max maxfanspeed
SETFANSPEEDCOOLING:
fanspeed = t * fanconstant5 / fanconstant6 'set fan speed based on current temp
fanspeed = fanconstant4 - fanspeed * 4 max maxfanspeed
