I'm a newbie and am having problems configuring 2 chips.
I have configured 2 chips (powered by the same 4.5 power supply).
When a reed switch is activated (connected to an 08m chip) an led goes off and then a signal is sent (via a simple wire) to the second chip (18x chip) where another led flashes.
The goal is to see how one chip can interactively talk to another.
If I don't connect the 08m by the wire, the reed switch & led go off fine. When I connect the wire over to the 18x, then the 08m chip will no longer fire - and the 18x doesn't light up.
Do I have the programming or the wiring configured correctly?
PICAXE-08M
.--._.--.
--| 1 8 |--
--| 2 7 |--
--| 3 6 |-- positive to reed switch
--| 4 5 |-- led; output wire to pin 6 of picaxe-18x
PICAXE-18X
.---._.---.
--| 1 18 |--
--| 2 17 |--
--| 3 16 |--
--| 4 15 |--
--| 5 14 |--
input wire --| 6 13 |--
--| 7 12 |--
--| 8 11 |--
led --| 9 10 |--
PICAXE-08M Program
b1 = 0
readadc 1, b1
if b1 = 4 then flash
flash:
high 2
pause 50
low 2
pause 50
b1 = 0
pause 50
PICAXE-18X
b1 = 0
readadc 6, b1
if b1 = 6 then flash
flash:
high 2
pause 50
low 2
pause 50
PICAXE-08M
.--._.--.
--| 1 8 |--
--| 2 7 |--
PICAXE-18X
.---._.---.
--| 1 18 |--
--| 2 17 |--
--| 3 16 |--
--| 4 15 |--
--| 5 14 |--
--| 7 12 |--
--| 8 11 |--
led --| 9 10 |--
PICAXE-08M Program
b1 = 0
readadc 1, b1
flash:
high 2
pause 50
low 2
pause 50
b1 = 0
pause 50
PICAXE-18X
b1 = 0
readadc 6, b1
flash:
high 2
pause 50
low 2
pause 50
