radiogareth
This is the situation: I'm putting a different (non-original) engine into a Mazda RX8 which has (had) a rotary engine. Understandably the rotary engine does not have a conventional ignition trigger wheel (such as the 36-1 Ford device), but it does have the commonly used VR sensor. Its not a problem other than the original Mazda ECU/car management ecu expects an engine signal before it will turn on the electric power-assisted steering rack. It also drives the rev counter. One fix is to mount a replica Maxda trigger wheel onto my new engine, but since my new engine outputs a suitable RPM signal I thought 'why not get a Picaxe to replicate the Mazda pattern'. The new engine runs on its own ECU and outputs a '2 pulses per rev.' tachometer signal.
I envisage a Picaxe counting these two pulses and outputting the specific stream at an engine speed related rate. The power steering is not speed sensitive, but clearly the tacho is!
The attached picture shows what I'd need to replicate, every two times an imput pulse is received.
My initial thoughts are that a simple squarewave of appropriate M:S ratio may well work. To shape the pulse a bit I wondered about a simple RC filter (or CR) or perhaps use a picaxe output to drive a spare sensor and physically place the driver next to the Mazda original.
Maybe someone has done this already. Maximum RP of the donor will be 6,500 rpm, so the styytem will need to scale accordingly as the engine speed rises.
Thoughts and comments??
Thanks
Gareth
Thanks
Gareth
