Hey Guys,
I was wondering if I could get some input.. I am looking to build add on modules for my Honeywell Home security System. I installed the system myself last year and am pretty educated in that department. As well I have build and played with several picaxe chips using serial in/out from chip to chip. I wouldn't say I found it easy to do, but it also helps when I select the code to send as well as the baud rate and such. I have yet to work with other peripherals other then picaxe using serial in/out.
The Alarm panel I have has several add on module outputs, that use serial to the module to turn lights on and so on.. I want to build a simple module to turn leds on..
Here's the question, And yes I have spend hours searching the net.. with no real solid answer..
What do I need as far as equipment or programs to be able to connect to the serial lines of the alarm panel and read what is being transmitted.??? So I can program my picaxe to look for certain strings of code.. I have a fluke 2 channel scope.. But I don't think that's what I need.. I am willing to download or purchase software, make cables and so on.. I use need your input in regards where to start... suggestions on programs or equipment you have used that works to get the job done.. I don't need anything overkill.. But I have no idea the baud rate or what type of information is being sent or in what manner.. I have 5VDC, GND, TX, RX.. from alarm panel now.. If I touch the screen on alarm panel and select "lights" then On, Off it thinks its sending it to a module.. But there is nothing there... I want my picaxe to answer.. and then do as I ask..
Thanks guys.. I will take your advice seriously and research anything you suggest..
Steve
Steve
