Random Numbers
DoomDuck
Hello,
I wrote the simplified code below so that one of four light displays would appear randomly and it works perfectly in the simulation, but when I program my 28x PICAXE, it doesn't seem to work and only the collapse segment of the code continously loops. Where did I go horribly wrong?
thanks,
DD
	random w0
	if w0 > 30000  then random1
	if w0 < 30000 then random2
random1:
	random w1
	if w1 > 30000 then chain
	if w2 < 30000 then alternating
random2:
	let w2 = timer
	random w2
	if w2 > 30000 then wash
	if w2 < 30000 then collapse
collapse:
	high 4
	wait 2
	low 4
wash:
	high 1
	wait 2
	low 1
chain:
	high 7
	wait 2
	low 7
alternating:
	high 0
	wait 2
	low 0
eclectic
@DD.
Until you get a more knowledgeable reply,
1. The following modifications might help
	random w0
random1:
	random w1
	if w1 < 30000 then alternating ; ***********
random2:
;	let w2 = timer ********
	random w2
collapse:
	high 4
	wait 2
	low 4
wash:
	high 1
	wait 2
	low 1
chain:
	high 7
	wait 2
	low 7
alternating:
	high 0
	wait 2
	low 0
2. However, do you simply want four outputs (7,4,1,0) to light randomly?
If so, here's a long-winded version which might help
#picaxe 28X1
	random w0
	w1 = w0 //4 ; see #rem below
	on w1 gosub zero , one, four, seven
zero:
	high 0
	wait 1
	low 0
one:
	high 1
	wait 1
	low 1
four:
	high 4
	wait 1
	low 4
seven:
	high 7
	wait 1
	low 7
#rem
http://www.picaxeforum.co.uk/showthread.php?t=7799
e
There are two problems - RANDOM creates a pseudo randon number and all random numbers in variables will follow the same sequence. I'm afraid my brain's not in gear at this time of evening to work out a solution.
ljg
generate random numbers in a loop until some external stimulus value is met, i.e. stay in a generating loop until a button is pressed to get a random seed for w0
alternatively, use the result of reading a scaled value as the seed (light level, battery voltage, sound level, discharge rate of an air gap capacitor, etc.
If it's a robot, do some math on the sensor values for your sonar, IR distance sensors, tilt sensor, GPS time reading, etc. and use that as a seed. a Sharp analog distance sensor without a big smoothing cap would be particularly jumpy.
external stimulus is sure to be more random, and the random seed will be different when you need it to be.
