Hi all,
I have a little robot project where I am reading a servo channel output from a futaba radio control receiver into a 28x1 using the pulsin command. I have this working on my test bench but as soon as I tried powering it from a battery supply it stops working.
I have a simple loop that reads the pulsin command and then displays this to the PE terminal. If I use my benchtop 5V supply to power my circuit it works fine (actually 4.94V). If I use the RC receiver battery pack to power the picaxe it works fine (4.6V). If I use a 11.1V li-po battery through a 7805 voltage regulator with caps the picaxe does not receive any pulses (5.07V).
This seems strange. The rx receiver is still definetly working because if I plug a servo into the channel I am reading it moves it accordingly. I am wondering if the different voltages are causing a problem. There shouldnt be an issue using the 11.1V li-po with voltage reg?
I obviously have the 0V from the rc receiver pack and my supply connected together. I have even tried powering the rc receiver from my regulated 5V and this made no improvement.
Any suggestions why the pulsin command would suddenly start reading zero when using this different voltage supply?
Thanks all
Thanks all
