Andrew Cowan
I am trying to create a rough, moderatly high power pot using a FET.
I am putting the output of an 08M through a 380 ohms resistor into the gate of the FET. The FET has a 0.47uF capacitor on it (to ground), and a 22K drain resistor.
However, this seems to charge up too easily. What values of R and C would you recommend for this? I am basically tring to create an analogue voltage of 0-5V. Is a drain resistor needed? Is the 1K resistor needed, or should I PWM straight into the cap?
Thanks,
A
Thanks,
A
