Hmm, the Sod Pers I use recommends 50-60 deg C, on the side of the container. Wonder if I've been overcooking a few. I've been experimenting with the blue Press n Peel film - someone gave me a pack as a present a while ago so I thought I should use it. It's kind of varied. The results can be a little smudged. I clean the copper really well, have the iron as hot as it will go, no steam, a piece of paper between the film and iron, and sit the iron - applying a bit of pressure - for 2 or 3 minutes. The results aren't as crisp as I'd like. Mycroft suggested glossy paper to reverse-laser print on so I'll give that a go.
For those that also iron-on, I'd be keen to know your thoughts on downward pressure, iron temp, etc and whether any of you do anything radical like clamp between metal plates and bake in the oven.
