AndyGadget
For an audio project on an 18m2, I'm trying to change the PWM frequency without issuing a new PWMOUT command. This is to avoid a reset of the PWM timers which causes the audio output to be distorted.
This was easy on the 08m - Poking the PR2 register for the frequency and CCPR1L and CCP1CON registers for the duty cycle worked a treat.
On to the 18M2 - The PIC16F1826/27 datasheet states that Timers 2, 4 and 6 are associated with the PWM function. Changing the PR2 (period) register after a PWMOUT command (using POKESFR $1B) has no effect on the output frequency of either pin B.3 or B.6 so I'm trying to do the same with the PR4 and PR6 registers.
PR2 is easy as it's in register bank 0 and accessible with the POKESFR command, but PR4 and PR6 are registers $16 and $1D in bank 8 which is not.
So the question is, is there a way or writing to these registers other than using the POKESFR command, and if there is, is changing these likely to give the result I'm after?
#picaxe 08m
'#no_data
'#no_table
setfreq m4
data (15,21,29,41,58,81)
symbol piezo = 2
symbol LED = 0
symbol sw1 = pin3
symbol rnd = w6
symbol rndh = b13
symbol rndl = b12
symbol W = w5
symbol Wh = b11
symbol Wl = b10
symbol Wx = w4
symbol F = b0
symbol R = b1
symbol t1 = b2
symbol t2 = b3
symbol adc = b4
symbol adcx = b5
symbol hi = 1
symbol lo = 0
symbol true = 255
symbol false = 0
symbol arpst = $80
f = 128
w = 255
pwmout pwmdiv4, piezo,f,w
readadc 4,adc
adc = adc / 40
if adc <> adcx and adc <> 6 then
high led
read adc,f
adcx = adc
w = f * 2
pwmout pwmdiv16, piezo,f,w
pause 100
low led
end if
if adc = 6 then
adcx = adc
end if
f = f * 32 / 30
poke $92,f
w = w * 31 / 32
wx = w / 4
poke $13,wx
wx = w AND %00000011 * 16 OR %00001100
poke $15,wx
pause 10
