Greetings All
I upgraded PE6 from 6.0.6.1 to 6.0.8.8 today and loaded a previously known good project.
When I ran the syntax check it failed and came up the following error message
bcdtoascii TC_Temp_Data, @ptrinc, @ptrinc
Syntax error on line 379 at/before position 43
Error: @ptrinc cannot be used as for variable!
Prior to the line of code bcdtoascii TC_Temp_Data, @ptrinc, @ptrinc I've set the ptr to a correct value. I use variations of this line of code in multiple places and it fails in all of them
Has something changed in the picaxe system between the versions of PE6? As I said earlier as far as I'm concerned this was working code
I don't have a copy of the old version of PE6 to check and see if the error goes away.
I did a web search on that error code but only came with post from 2007
http://www.picaxeforum.co.uk/showthread.php?7109-ptrinc-cannot-be-a-destination-variable
I don't think the solution suggested applies now
Any suggestions?
Regards
Ian J
Any suggestions?
Regards
Ian J
