Recently I had the opportunity to play with PID Controllers and I managed to make a PD Controller with a Picaxe 08M. I'm sharing with the hope that it will find some use for someone.
The setup is build on a AXE021, Picaxe-08 Proto Board using minimal components. A schematic is attached as well as photo's of the setup.
It uses a DS18B20 temperature sensor to read the temperature and the output is controlled via a BC337 NPN transistor using a 500 Hz Pulse Width Modulation (PWM). Data is echoed to PC as CSV.
For testing the temperature sensor was tapped to a 12V, 5 W light bulb used as a heat source.
Enjoy.
Enjoy.
