When Dropping objects this is true as gravity on earth is constant.Surely if the angle and initial velocity are always the same then the object should travel the same distance regardless of its weight.
Whilst it might take more energy to get a heavier projectile to the same initial velocity surely the thing that determines how far it travels
before it hits the floor will be governed by gravity and that should be the same regardless of the weight . The size and shape might make
a difference due to drag but weight shouldnt matter . Try dropping a bowling ball and a tennis ball from the same height and they hit the floor together.
Don
