Thank you for the quick reply, nick12ab. I need help please in finding which lines of the code to change and what to change them to. I am new at this!You change it in the code and re-download it.
EEPROM $00, (" Serial OLED ") ; store msg in the EEPROM memory
#else
EEPROM $00, (" Serial LCD ") ; store msg in the EEPROM memory
#endif
EEPROM $10, (" www.picaxe.com ") ; store msg in the EEPROM memory
EEPROM $20, ("This is msg 2 ") ; store msg in the EEPROM memory
EEPROM $30, ("This is msg 3 ") ; store msg in the EEPROM memory
EEPROM $40, ("This is msg 4 ") ; store msg in the EEPROM memory
EEPROM $50, ("This is msg 5 ") ; store msg in the EEPROM memory
EEPROM $60, ("This is msg 6 ") ; store msg in the EEPROM memory
EEPROM $70, ("This is msg 7 ") ; store msg in the EEPROM memory
EEPROM $80, ("This is msg 8 ") ; store msg in the EEPROM memory
EEPROM $90, ("This is msg 9 ") ; store msg in the EEPROM memory
EEPROM $A0, ("This is msg 10 ") ; store msg in the EEPROM memory
EEPROM $B0, ("This is msg 11 ") ; store msg in the EEPROM memory
EEPROM $C0, ("This is msg 12 ") ; store msg in the EEPROM memory
EEPROM $D0, ("This is msg 13 ") ; store msg in the EEPROM memory
EEPROM $E0, ("This is msg 14 ") ; store msg in the EEPROM memory
EEPROM $F0, ("This is msg 15 ") ; store msg in the EEPROM memory
#ifdef use_OLED
EEPROM $00, ([COLOR="#FF0000"]" Serial OLED "[/COLOR]) ; store msg in the EEPROM memory
#else
#endif
EEPROM $10, ([COLOR="#FF0000"]" www.picaxe.com "[/COLOR]) ; store msg in the EEPROM memory
Thanks Russbow. I got that part and changed the values of b0 and b1 at the Let commands following "#def use_welcome". But when I run a simulation, there is no output and the editor asks for some Serin data.I havn't played with the oled display but looking at the firmware code I think these are the relevant lines that you will need to change to personalise yourstored messages.
For instance, change "This is message 2 " toCode:EEPROM $00, (" Serial OLED ") ; store msg in the EEPROM memory #else EEPROM $00, (" Serial LCD ") ; store msg in the EEPROM memory #endif EEPROM $10, (" www.picaxe.com ") ; store msg in the EEPROM memory EEPROM $20, ("This is msg 2 ") ; store msg in the EEPROM memory EEPROM $30, ("This is msg 3 ") ; store msg in the EEPROM memory EEPROM $40, ("This is msg 4 ") ; store msg in the EEPROM memory EEPROM $50, ("This is msg 5 ") ; store msg in the EEPROM memory EEPROM $60, ("This is msg 6 ") ; store msg in the EEPROM memory EEPROM $70, ("This is msg 7 ") ; store msg in the EEPROM memory EEPROM $80, ("This is msg 8 ") ; store msg in the EEPROM memory EEPROM $90, ("This is msg 9 ") ; store msg in the EEPROM memory EEPROM $A0, ("This is msg 10 ") ; store msg in the EEPROM memory EEPROM $B0, ("This is msg 11 ") ; store msg in the EEPROM memory EEPROM $C0, ("This is msg 12 ") ; store msg in the EEPROM memory EEPROM $D0, ("This is msg 13 ") ; store msg in the EEPROM memory EEPROM $E0, ("This is msg 14 ") ; store msg in the EEPROM memory EEPROM $F0, ("This is msg 15 ") ; store msg in the EEPROM memory
"This is TinkerJim " and so on
Thanks also Westaust55. Yes, I have the OLED and the 133 firmware downloaded and pasted into the Programming Editor.@TinkerJim,
Firstly there is the assumption, based upon your comment about downloading the firmware, that you have an AXE133 based OLED display and not the AXE033Y based OLED display.
In this case as already mentioned you need to alter the message test and download the revised program into the 18M2 which controls the display.
The two lines of program which by default show the messages in the OLED are highlighted above in red.Code:#ifdef use_OLED EEPROM $00, ([COLOR="#FF0000"]" Serial OLED "[/COLOR]) ; store msg in the EEPROM memory #else EEPROM $00, (" Serial LCD ") ; store msg in the EEPROM memory #endif EEPROM $10, ([COLOR="#FF0000"]" www.picaxe.com "[/COLOR]) ; store msg in the EEPROM memory
The other messages in the program code as "This is msg 2" through to "This is msg 15" are others you may refefine but not used by default at start-up.
I'm not sure exactly what you have changed in the code but if you just want to stop the welcome message being displayed on startup simply comment out the "#define use_welcome" line as westaust55 suggests.Thanks Russbow. I got that part and changed the values of b0 and b1 at the Let commands following "#def use_welcome". But when I run a simulation, there is no output and the editor asks for some Serin data.
I even tried simulating the unmodified firmware program and the same thing happens.
I am reluctant to program the module 18M2 if the simulation doesn't work.
Thanks westaust55! Enabling the define use_OLED line did the trick; I didn't see the "Winstar" name on the module, so wasn't sure what to do with that line.;define use_OLED ; enable this line for Winstar OLED modules
you need to remove the semicolon from the #define line as highlighted in red
Thanks, hippy ! Your comment about why the welcome mssgs do not appear in the simulator's Serial Output buffer window registered clearly! I have the OLED working just fine now !!I'm not sure exactly what you have changed in the code but if you just want to stop the welcome message being displayed on startup simply comment out the "#define use_welcome" line as westaust55 suggests.
The simulator will handle #DEFINE and #IFDEF just like using a real PICAXE so the likely scenario is that you're expecting something in the Serial Output buffer but that won't happen because it's not serial output to the LCD / OLED.
It is a Winstar OLED module but it should have came with a sticker saying 'Winstar' on the back of the module.I didn't see the "Winstar" name on the module, so wasn't sure what to do with that line.
Oops! Yes, WINSTAR is right there in big bold letters on the sticker! I was focused on the model # etc. in the fine print!! Yet another lesson in humility today!!!It is a Winstar OLED module but it should have came with a sticker saying 'Winstar' on the back of the module.
