For the most part the Programming Editor is easy to use and the extra functions such as simulation, PWM wizard etc. are very welcome, however there are two issues regarding editing code that bug me no end:
1: Scroll bar behavior; the horizontal bar is always there and can be scrolled far beyond almost any single line length that anyone will ever create, even when there's no code in the window. When you scroll the vertical bar to the bottom it scrolls the code up so far that you only see the last line.
2: Limbo zone at the end of the code; if you're editing code and you move the cursor to the very end of the last line and press the right arrow, the cursor goes into "limbo" where whatever you type doesn't appear and the only way to get it back via the keyboard is to press the left arrow (sometimes holding it down if you pressed the right arrow too much) or the up arrow.
Can we expect to see these fixed one day?
